Pure Power 10 400w or 500w?
Froug
Key components (pretty old, I know):
i5-2400 (Non-K, so no overclocking. Motherboard doesn't support OC anyway)
ASRock H67M
GTX 770 Amp!
The system would probably draw 300 (?) watts at load, so considering the be quiet! Pure Power 10 400W or 500W.
I heard that the PSU would be most efficient at 50-80%, so would the increased efficiency in the 500W worth it for extra money?
Which PSU should I get?
depends on price difference. You will most likely need a UPS too.
Desktop benching:
I never considered that. How much should I reasonably spend on it?
compare price to similarly spec and quality units? there's a PSU tier list in the forums
Desktop benching:
I mean how much should I spend on the UPS you mentioned
no idea, not in that region. Sorry
Desktop benching:
