UPGRADE HELP CPU/MOTHERBOARD
Solved by Jurrunio,
CPU first, at least you can run the CPU at stock speeds on the B360 board, with hyperthreading.
do not buy cheap boards
3
1
INotPablo ·
Posted in CPUs, Motherboards, and Memory5 -
3
gentlemanspot ·
Posted in Console Gaming0 -
1
