Need hdmi to display port for PS4
peep
I'm getting a PS4 Pro, but only have one display port connection on my monitor, so I need a display port to hdmi cable that will work on my PS4 Pro and Acer monitor. I've been looking but can't find any, please help!
You'll need an active (not passive) HDMI to Displayport adapter which is expensive.
CPU: AMD 3800X GPU: GTX 1080 Ti RAM: (16GB) 2x Corsair 8gb DDR4 3200Mhz Drives: SanDisk 240GB SSD, Samsung 500GB SSD, WD 1TB HDD
Motherboard: MSI X470 Gaming pro plus PSU: Gigabyte 650 watt Monitor(s): 27 inch AOC 1440p
What you need is hdmi to dp, not the other way around.
It needs an active converter a lot more expensive than regular dvi to hdmi.
https://www.amazon.com/HDMI-DVI-DisplayPort-Active-Converter/dp/B004I6IYSM
14 minutes ago, M.Yurizaki said:
The monitor doesn't have an HDMI or DVI port?
I'm very curious about this monitor.
https://www.amazon.co.uk/Acer-XB240H-Monitor-inch-1080P/dp/B00P67ZW8M I have this monitor, but it doesn't have 2 hdmi ports as displayed. I was thinking of just biting the bullet and getting a 4K monitor for the ps4 pro, any suggestions?
Yeah that is way too much, might as well just get a 4K monitor for my ps4 pro and spend less money overall, any suggestions?
I've unfortunately found that out, any suggestions to a 4K monitor for a ps4 pro?
16 minutes ago, M.Yurizaki said:
What's your budget?
£300-£400
Why not just get an HDMI splitter?  It's cheap and works.
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
