DSR and DLSS
8 minutes ago, Hi P said:I was reading about DSR and DLSS on reddit and apparently DLSS is only available in 4K resolution, right, a couple users said to enable DSR 2.25 at 1440p to enable 4K and therefore DLSS, but I'm a bit confused by this.
1.- Doesn't DSR virtually multiply your native resolution by that factor? which would mean DSR 1.5 at 1400p would be enough for 4K? (2560 x 1.5 = 3840 --- 1440 x 1.5 = 2160)
2.- Why do most people leave DSR Smoothness in 33%?
Thank you
1- DSR does render the graphics in 4K if you use that said multiplier if you calculated it right, and then it re-render it in 1440p for your screen to be able to show the image. Keep in mind it might lower your monitor's hertz if you use DSR you might want to look at this.
2- Because it's the default smoothness and I as well think it's "okay"
