So I play a lot of gaming like fifa, maddden, call of duty, battlefield, tomb raider.  I play them on my led tv as I don’t have a gaming monitor.  All resolution is 1920 x1080.  In all my games I have it on the highest graphic setting and v-sync on (or I getting a lot of tearing on my tv).  My CPU usage is under 50% and GPU under 50-60%.  When I run my games on 4K on my other 4K tv my FPS is 30 and GPU usage is at 98%, which I understand since it rendering more details.
Now I have never play Assassin’s creed games and bought Assassins Creed Odyssey.  The games is beautiful but my GPU usage in the game is 96% at 60FPS 1920x1080 @62c and in my graphic card ram says 4gb used out 8GB in the game menu, my CPU is at 35% @ 52c I don’t know what if that’s normal.  Please let me know .
My system is in my signature.
My PC:
CPU: AMD Ryzen 5 2600X Processor (4.4Ghz), MOBO: GIGABYTE X470 AORUS Gaming 7 WiFi (AMD Ryzen AM4/ X470/ Intel Wave 2 WiFi/M.2), RAM: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3000MHz C15, GPU: Gigabyte nVidia GeForce GTX 1080 Windforce OC GV-N1080WF3OC-8GD Graphics Cards, STORAGE: 120GB CRUCIAL SSD, 1TB WD BLUE, COOLER: Cooler Master 212 EVO RGB Black Edition, FANS: 4 x MasterFan MF120R RGB (2 Front, 1 Back, 1 Top), 1 x Noctua NF-P12 Redux 1700 RPM(Back off Cooler), PC CASE: Cooler Master MB500 case, PSU: EVGA 750 BQ.
My Kids PC:
CPU: AMD Phenom II x4 955 (95watt @3.5Ghz @1.40V), MOBO: ASUS M2A-VM, RAM: Kingston 8GB (4x2GB) DDR2 800MHz, GPU: nVidia GT 710 2GB DDR3 (OC’ed Clock to 1300Mhz and Memory to 950Mhz), STORAGE: 250GB HDD, 500GB HDD, COOLER:  Cooler Master 212 EVO, PC CASE: Cooler Master Q300L , FANS: 3 x upHere RED LED Fans (2 Front, 1 Back), PSU: Generic 300 Watt PSU.
Console:  PS4 - vjizzle2384
https://linustechtips.com/topic/1007553-gtx-1080-96-usage-help/
Just now, GoldenLag said:
what GPU are you running?
Did you read the title...?
https://linustechtips.com/topic/1007553-gtx-1080-96-usage-help/#findComment-12073897
something i question my short term memmory............
edit: *sometimes.
edit2: sometimes i question my spelling aswell. and i write better english than my native language apperantly.
https://linustechtips.com/topic/1007553-gtx-1080-96-usage-help/#findComment-12073900
Gigabyte gtx 1080 wind force oc
My PC:
My Kids PC:
https://linustechtips.com/topic/1007553-gtx-1080-96-usage-help/#findComment-12073901
performance doesnt seem to be out of the ordinary. Assasins creed oddesey is known to be quite taxing. mostly on the CPU though.
afaik the GPU should be running around 90%, other than that it seems to be fine
https://linustechtips.com/topic/1007553-gtx-1080-96-usage-help/#findComment-12073916
The only game that is taxing my CPU is GTA, but Assasin Creed is only game that uses alloy if my GPU
My PC:
My Kids PC:
https://linustechtips.com/topic/1007553-gtx-1080-96-usage-help/#findComment-12073923
2% utilization isn't really anything to worry about if you're still getting the performance you want. And it's up in the air what GPU utilization really means since a GPU core has many sub-units in it and some of them are specialized, meaning they may not be used as often. Is utilization counting up all of those GPU resources being used? I dunno.
Anyway, this isn't something I'd lose sleep over. Even if you translated utilization % to FPS, you'd only gain like 2 FPS if you got it to 100%.
https://linustechtips.com/topic/1007553-gtx-1080-96-usage-help/#findComment-12073957
My question is I’ve never got 100% or anywhere near 90% usage in GPU until I played this game, and didn’t know if that’s bad.
My PC:
My Kids PC:
https://linustechtips.com/topic/1007553-gtx-1080-96-usage-help/#findComment-12073972
No, that's not bad. 100% GPU utilization is the goal if you're trying to push as many frames as possible. If it's significantly less, the GPU isn't going to be producing as many frames per second as it could.
https://linustechtips.com/topic/1007553-gtx-1080-96-usage-help/#findComment-12073987
Oh ok lol I was thinking the low the usage was good, cause I reading about bottleneck and was talking about high usage bottlenecking
My PC:
My Kids PC:
https://linustechtips.com/topic/1007553-gtx-1080-96-usage-help/#findComment-12074121
My PC:
My Kids PC:
https://linustechtips.com/topic/1007553-gtx-1080-96-usage-help/#findComment-12074123
