Hello guys,
So, i made my first ever build this november, and i recently made the decision to swap psu's, i got a corsair tx750m 80 plus Gold, because i got a rx Sapphire PULSE RX Vega 56, and it says recomended wattage to be 750W, i was able to start the computer and everything seems fine, i install latest drivers for my pc with ''drivers easy'' software, and still everything seems fine, i run a benchmark test with heaven benchmark 4.0 from unigine, and i get 68C degrees max after a while (20 mins) meanwhile the hbm temp is at 75c, and fan speed only goes at 33% max, and got some drops in core clock (from 1535~ not constant to 1400 for example) and it did dropped some frames, but nothing from the other world, now the problem is when i was trying to play league of legends (way less intense i assume) and stream, and after like 5-10 mins of gaming my monitor flashes black for like 2 seconds, and then shows image again, and it happened like 5 times more.. It's very annoying and after i took the stream down, it stopped happening, and it's weird because i also opened core temps software that indicated that cpu temp was only max 56c, and gpu was at max 45.. and im very scared because i've spend all my budget already on this computer, and i don't know what to do, what do you guys think? is it a cpu overheating problem? or a gpu problem? im very scared so thanks in advance.
By the way my full specs are:
-Ryzen 5 2600 with stock cooler non oc, runs at 1.208V with 3.4-3.7 ghz
-Sapphire PULSE RX Vega 56
-Aegis 2x8GB ram 3000mhz oced to 2933 with xpm profile from msi gaming plus motherboard
-Msi gaming plus x370 motherboard
-250gb samsung evo 860 sdd
-corsair tx750m
-koolink rgb case
-hp 25x gaming monitor at 144 hz non oc, at 1ms with amd freesync always on.
If you could be so kind as to help me i'll be eternally grateful, i'm really loving pc building, and i loved to build my first one, but i would hate it for it to become a disaster.
Ps. By the way i am running windows at ''high performance'' energy profile, and i also am using an old keyboard as i wasn't able to get a new one yet, it's an old acer (6-7 years) that came with my old pre rig. Thanks again.
https://linustechtips.com/topic/1006369-need-help-with-bizarre-problem-1st-build/
Didn't read all of it but all I can say is that CPU temps at 56C and GPU temps at 45C is very low. If you aren't seeing 85+C you are all good, even at 80C you won't damage components just prolonged use at those temps is not recommended.
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
gpu temp looks too good to be true!
what the gpu usage and temps at gaming when screens shuts down? this may give us more clue
25 minutes ago, homeap5 said:
Try to change monitor cable.
I will try to change to display port as soon as i get one.
gpu usage was at around 75-80% at time of screen flash and temp was 45c and hbm ram temp was at 75c, cpu was at 47.6c, that's why im so confused those don't seem like temps that would make it shut down, the weird thing is it says that fan speed and usage is 0 at all time..as u can see below, maybe a faulty gpu? i hope its just a cable issue, ill try to buy a display port 1.2 tomorow and check it, i hope gpu its fine, i got it on black friday and was a good deal..
16 minutes ago, Z3R0 CHANC3 said:
Mysterious.   Update your bios if there's an update.  If not, re-load defaults on the bios.
thanks i will try that
