Best GTX 1060 6GB for heavy use 24/7?
Hallah
I want to buy a new card 1060 6GB and RX 580, can you recommend the best models that run coolest?
The ROG Strix 1060 6GB and Strix RX 580 8GB
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
temps really dont matter when it comes to 24/7 operation. as long as it isnt running at 90C offcourse, but they dont do that anyway
Pretty much any that has a dual fan design.
Personal Desktop":
Luna, the temporary Desktop:
Just now, LukeSavenije said:
exept the armor I would add
The thing is, the issue with Armor's bad cooling is that it has lower clocks and can hind gaming performance yes but if he wants something for "24/7 usage" I'm guessing it's for hardware acceleration where it'd matter less.
Like mentioned as long as the GPU is on the 80's and no more, it's hot but won't die (if it runs without issue for the first 5 hours at least).
Also MSi Aero is the one every one should avoid as MSi binning process mainly picks the actually WORSE processing chips that can't do any factory OC at all and throws them on the cheaply build blower style Aero line up.
Personal Desktop":
EVGA's Dual fan, as in case they fail, EVGA has the best customer support, and sometimes will give you a upgrade
The single fan EVGA SC 1060 is a great lil card
