Ups wattage
Go to solution Solved by Jurrunio,
under max stress 8700 only draws 150-175w (even 8700k only draws 200-230w) while 1080 with the most ridiculous power limits only draw 250w. I see no need for even a 750VA UPS, not to mention more than that
Hello, i recently bought a 850va ups for my i7-8700, gtx1080 pc, and a friend told me its not enough. A ups calculator shows that the recommended amount is 750va so i took 100 more. He told me that when the pc is on stress it will go much higher than 850va..i know alot about pc parts, but i know nothing about ups and how it works.. I would be glad for some help, this ups is still in case and returnable.
https://linustechtips.com/topic/1004030-ups-wattage/
That UPS is fine for your PC.
https://linustechtips.com/topic/1004030-ups-wattage/#findComment-12042181
Desktop benching:
https://linustechtips.com/topic/1004030-ups-wattage/#findComment-12042185
This.
Now, if you need your PC be on longer then just shutting down to save work.... as in you want to game THRU the power outage... then you need to up the VA to 1000 or more.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1004030-ups-wattage/#findComment-12042189
19 minutes ago, jstudrawa said:
This.
Yeah but in case im in game while theres a power outage, what will happen to the pc?
https://linustechtips.com/topic/1004030-ups-wattage/#findComment-12042242
It'll remain on, I've had this happen a few times over the summer.  The only reason I realized my power went out is because I lost my internet connection.
At 850 you'll have enough time to close out of applications and safely shut down your computer.
Limit the amount of devices hooked up to your UPSs battery though.  Monitor and PSU is really all you need.
"And I'll be damned if I let myself trip from a lesser man's ledge"
https://linustechtips.com/topic/1004030-ups-wattage/#findComment-12042265
no problem , thank you!
https://linustechtips.com/topic/1004030-ups-wattage/#findComment-12042352
