Best Running IEMS For audiophile
Lsat0902
I’ve started running and I want solid IEMS SUB 150$ slightly to the bass side of thinks but with clear high and mids. Suggestions?
Thanks- Lsat
Hi. If you wanna go wireless i strongly recommend you lock at the Jaybird  Bluebuds or Run line-up ;
But then I have another suggestion and the best in my humble opinion (these are the ones that i have): You should get the KZ - ATE HIFI (these will get your .flac's a run for their money [pun intended :)  ]) for 10-20 bucks from aliexpress, and also while you're there get some rubber around the ear hooks so they stay in ear even in case of natural disasters , and the best thing is that  they come in the box with a set of comply / memory foam eartips which is a win in my book.
