Search In
  • More options...
Find results that contain...
Find results in...
Ps4 on phone not supporting it?
Vod
 Share
Hello!
So I want to connect my ps4 controller on my phone (xperia xa1) but it tehnicky doesn't support it.
Is there maybe a way to bypass that with an cable or change something in the setting?
İf you can't connect with bluetooth, you can use OTG cable.
On 11/30/2018 at 8:26 PM, Vod said:
Hello!
What doesn't support it?!
Pressed Share + PS Button at the same time, until its starting to blink and then look for bluetooth devices on the phone?!
"Hell is full of good meanings, but Heaven is full of good works"
Thats what I did tdo, when I connect it, and try to move some apps in my main screen, nothing happens, I downloaded an app that detects whats connected to it and the ps4 controller didn't show up.
I already tried that, didn't work.
 Share
