4 pin fan splitter?
boey
Hi, I bought a ML240L RGB from Cooler Master but I realise my micro itx motherboard only has 2 4 pin connectors, whereas the AIO needs a 3 pin for the pump and 4 pin for the fans.
Would it be okay if i bought a 4 pin fan splitter(it splits into 4) and plugged it into one of the fan headers?
I don't know if it will sufficiently power the fans/pump enough or not, but there is one 3 pin connector(that's connected to the one of said 4 pin headers) that is connected to a SATA cable(i assume it's powering the 2 sata drives connected to this cable, since no other cable is attached to said sata cable), an AIO pump and 2 fans.
If I were to plug a 4 pin fan splitter into a 4 pin header on the motherboard, and attach 2 4 pin cables(from aio fans) onto the splitter, then attach the 3 pin pump header onto the other 4 pin header on the motherboard would it work? Thanks.
What motherboard are you using?
You can plug 3-pin fan things into 4 pin PWM headers - the connected device will just run at full speed unless it can be adjusted down in the BIOS or with motherboard fan control software.
For AIO pumps, a motherboard fan header should be fine for power, but I would not split it into pump + another fan.
Depending on the fans, you could run several off of the other fan header (I have a passive 3 way PWM splitter).
HEDT: i9 10980XE @ 4.9 gHz, 64GB @ 3600mHz CL14 G.Skill Trident-Z DDR4, 2x Nvidia Titan RTX NVLink SLI, Corsair AX1600i, Samsung 960 Pro 2TB OS/apps, Samsung 850 EVO 4TB media, LG 38GL950G-B monitor, Drop CTRL keyboard, Decus Respec mouse
Laptop: Razer Blade Pro 2019 9750H model, 32GB @ 3200mHz CL18 G.Skill Ripjaws DDR4, 2x Samsung 960 Pro 1TB RAID0, repasted with Thermal Grizzly Kryonaut
Gaming Rig: i9 9900ks @ 5.2ghz, 32GB @ 4000mHz CL17 G.Skill Trident-Z DDR4, EVGA RTX 2080 Ti Kingpin, Corsair HX1200, Samsung 970 EVO Plus 2TB, Asus PG348Q monitor, Corsair K70 LUX RGB keyboard, Corsair Ironclaw mouse
HTPC: i7 7700 (delidded + LM), 16GB @ 2666mHz CL15 Corsair Vengeance LPX DDR4, MSI Geforce GTX 1070 Gaming X, Corsair SFX 600, Samsung 850 Pro 512gb, Samsung Q55R TV, Filco Majestouch Convertible 2 TKL keyboard, Logitech G403 wireless mouse
Yeah ok thanks, I used 2 fans on a splitter that connected to the chassis fan header and the pump on a seperate cpu fan header and it’s working fine. I realise my H61 board is too old for RGB headers so I need to spend more money on a cooler master fan hub to power the rgb by sata :(
Uh Gigabyte GA-H61M-S2PV
