Suggestions on how to turn down high RPM case fan.
PrincePickle
I recently bought a Cooler Master SickleFlow 120 case fan but it spins full speed at 2000 RPM which is too loud.  Tried adjusting the fan speed through the BIOS, but that hasn't had any affect.  Any ideas on how to reduce the RPM on the case fan without using 3.5 or 5.25 bay fan controller?  Its an ITX build and don't have a lot of space for additional hardware, thanks.
MY PC: Case: Corsair Carbide Air 540, Motherboard: AsRock 970 Extreme 4, CPU: AMD FX 4300 AM3+ GPU: EVGA GTX 650Ti Boost 2GB SLI RAM: 4GB Corsair Vengeance 1600MHZ Low-Profile Black Memory PSU: Corsair CX 600M Cooler: Cooler Master Hyper 212 Evo OS Drive: Corsair Force LS 120GB SSD Data Drive: 500GB Seagate 5400rpm 2.5" laptop drive OS: Windows 8.1 64bit Lights: NZXT Hue Kit Keyboard: Cooler Master CM Storm Quickfire TK MX Blue Mouse: Wired Microsoft Mouse Monitor: Sony Bravia KDL42W654A 42" Smart TV + LG LG IPS234V-PN.AEK PS 23-inch IPS Monitor
Could get one of those low noise adapters
------------------------------------------------------I HAZ SHINY----------------------------------------------------------
Which mobo? You could use its own software, Speedfan or something like OpenHardwareMonitor. Unless fan is PWN, doing it from BIOS has hardly any effect.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
