Enquiry about a sideways angled fan and the noise it makes.
PaPaNurgle
https://www.amazon.com/dp/B0752BNKWG/ref=cm_sw_r_other_apa_R1ogAb78FSBC5
This PC has a fan that was installed sideways my gf and i didn't understand so we sent it back. we then got a new one and it also was installed sideways so we called customer support in which they told us that its supposed to be sideways.
But here is the thing, it was making an obvious sound that a fan makes when its hitting metal. The customer service rep said that's also normal too. Is this correct?
What do you mean by mounted sideways? and where was it mounted?
PC - CPU Ryzen 5 1600 - GPU Power Color Radeon 5700XT- Motherboard Gigabyte GA-AB350 Gaming - RAM 16GB Corsair Vengeance RGB - Storage 525GB Crucial MX300 SSD + 120GB Kingston SSD   PSU Corsair CX750M - Cooling Stock - Case White NZXT S340
Peripherals - Mouse Logitech G502 Wireless - Keyboard Logitech G915 TKL  Headset Razer Kraken Pro V2's - Displays 2x Acer 24" GF246(1080p, 75hz, Freesync) Steering Wheel & Pedals Logitech G29 & Shifter
1 minute ago, PaPaNurgle said:
Look at the picture, the fans on an angle.
You'll have to point it out to me cause i'm not seeing any angled fans from the pictures.
3 minutes ago, PaPaNurgle said:
Ohh the cpu heatsink fan, i was looking at the case fans lol.
Yeah that's normal for the stock coolers they use in pre-builts. They can be obnoxiously loud and make weird noises, so that's probably the sound you're hearing.
10 hours ago, PaPaNurgle said:
Both fans on that pic are very much normal. One being normal exhaust and other being stock cooler. You can control fan speed from BIOS or with mobo manufacturers software. But see if the cooler fan really is the one making noise.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
