Heavy ghosting on 6 ms monitor
Go to solution Solved by Glenwing,
32 minutes ago, Wyndmere said:
I got this brand new monitor(https://www.newegg.com/Product/Product.aspx?Item=N82E16824260311)  to replace my old 5 ms TFT monitor, but the new one feels much choppier and when i move the cursor while gaming i can notice ghosting trail on objects in the sky or where the terrain is uniform. Are there other things in play here other than response time? Thanks in advance! :)
Ghosting is determined by response time, but the advertised response time specs don't tell you what the response time is, you need to read detailed reviews that actually measure it.
https://linustechtips.com/main/topic/278610-display-technology-faq-mythbuster/
What do you have the refresh rate set at?
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
60 ofc :)
I understand that there is some variation, but didn't expect such a huge difference between a 5ms and 6ms monitor :(
49 minutes ago, WereCat said:
Check your monitor OSD menu for Overdrive option. Try higher values if it is there.
It has a response time option that can be set to either NORMAL or FAST, but when i set it to FAST there is horrible reverse ghosting (i can see it even with very slow mouse movements, i'm guessing like 300ms+)
