rear fan for h440
etze
hello guys
so i got an nzxt h440 and the rear fan is kinda loose and it makes a some noise when i open my PC for a few minutes..
i decided to buy another one and im thinking about getting a led fan, 140mm
thinking about buying an AEROCOOL led 140mm blue edition
it's cheap and seems decent for its price.
any other ideas?
What do you mean by it's loose? Are the screws not fully tightened?
Can you describe the noise?
