Why is my LAN speed the same as my real Internet speed?
LiquidGoo
Hello,
For some reason my transfer speed in a LAN network is EXACTLY the same as my real Internet speed. Is there anything that can be done to fix this?
All of my test were done on ethernet connected to my router.
How fast are your transfers and what devices are you transferring between?
PSU Tier List | CoC
Gaming Build | FreeNAS Server
My transfers are around 6,7 MB/s and I am transferring my files between a laptop connected to ethernet and a desktop PC also on ethernet.
Do you have the same speeds between different clients?
PSU Tier List | CoC
Just now, M.Yurizaki said:
And also what kind of transfer scenario are you doing? i.e., lots of files or not a lot of files.
Not a lot of files.
Yes.
What is the size of the files and what type of drives are being used (SSD, HDD)?
if you want to annoy me, then join my teamspeak server ts.benja.cc
9 minutes ago, M.Yurizaki said:
Disconnect the network from the internet and see if anything changes.
Nothing changes.
Files are from 1mb-500mb. Both clients are using a SSD.
1 minute ago, LiquidGoo said:
Nothing changes.
Have you checked both PCs nics are set to 1000Mbps vs 100 or 10?
What is the network path like? ( Pc - switch - pc)
2 minutes ago, M.Yurizaki said:
Well that seems to point out something's wrong with the router then. So, what's the router?
Inteno DG301
Yes, I have checked.
Network path is PC - Router - PC
3 minutes ago, LiquidGoo said:
Inteno DG301
What router do you have?
PSU Tier List | CoC
Inteno DG301
Did you check the network speed they were setup at? If it's at 100Mbps, then it would make more sense that the network transfers are slow. 100 Mbps is a typical fallback and at best you're looking at 12.5MB/sec. But I don't know how much overhead Ethernet has.
Which reminds me, cables could also be suspect.
They said it: Inteno DG301
EDIT: Oh poo, ninja'd. It was in the post you quoted.
I would try replacement cable just to rule that out.
Can you do an ipconfig /all on both systems and paste it here?
Additionally can you run an iperf test and see if the transfer speed is the same?
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | EVGA GTX1070 FTW | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO | 12 x 8TB HGST Ultrastar He10 (WD Whitelabel) | 500GB Aorus Gen4 NVMe | 2 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
