What monitor power supply to get
5 hours ago, Pc6777 said:Do they still make this model? I would want a new one so it lasts longer/caps might wear from sitting on shelf.
No. You would need to get a Generic One or a Used One.
Really all you need is 19v with a minimum 2.1A, at least according to the power adapter.
You would also need to figure out the barrel plug size and make sure the new one is Negative exterior and Positive Interior. -(+)
5 hours ago, Pc6777 said:Ok, I need the exact same voltage but it's ok if amps are higher but Amps can't be lower? And is it ok if it's like 1 volt off or could that still damage it in your experience?
Yes the Amps can be higher than what it needs, as the device will only draw what it needs.
As far as Voltage, it just depends on the device and its tolerances, it would be a safer bet to match what it originally had.
That would probably be fine, however with cheap power adapters like this, I would trust one with a Analog Voltage switch over a Digital Voltage Switch, if you can find one.
I couldn't give any recommendations however, I usually just purchase a 3rd party Generic Power Cord then double check it with a digital multimeter.
You could search around with the Power Adapters Model Number, or with the Monitors Model Number.
