Will Noctua NH-D15 work for my PC built?
WINNERBHAI
I think you will need a lower RAM profile
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
Primary PC:
4 minutes ago, Fasauceome said:
Just have to raise the front fan to clear the ram.= bigger case
i have chosen Corsair Crystal Series 680X RGB ATX Mid Tower Case !!!! so you are suggesting me to use ddr4 3200 ram.
Is there any way to use the ddr4 3600 ram? I'm very new in this pc building world, plz forgive me if i say anything stupid.
https://www.corsair.com/eu/en/Categories/Products/Memory/VENGEANCE-LPX/p/CMK16GX4M2B3600C18
the 680X is huge, it's not a problem
Primary PC:
12 minutes ago, WINNERBHAI said:
hey bro plz review my build, i have made on pcpartpicker
https://pcpartpicker.com/user/winnerbhai/saved/#view=7HycTW
Thanks for your suggestions
From what I can tell you only changed the ram. LPX is better value than Trident Z, but you clearly aren't going for value so it doesn't really make a difference
Primary PC:
