Stupid question - spec for sound quality
Gamer Schnitzel
I know this is probably a dumb question. I want to buy speakers for my computer soon. Is tehre a specification I can check to see whether a speaker system is good or bad quality..?
I don't know where you live, but for sure there are big stores that you can try the majority of the products before buying them
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
There isn't really a "spec" that specifies how good a speaker will sound. Even if speakers have the same measurements, they will sound different as measurements don't tell you everything about how good a speaker will be, as those measurements dont take into account distortion, Vertical dispersion, Horizontal disperson etc.
LTT's Resident Porsche fanboy and nutjob Audiophile.
Main speaker setup is now;
Mini DSP SHD Studio -> 2x Mola Mola Tambaqui DAC's (fed by AES/EBU, one feeds the left sub and main, the other feeds the right side) -> 2x Neumann KH420 + 2x Neumann KH870
(Having a totally seperate DAC for each channel is game changing for sound quality)
Many of the speakers in your list guys have high watt. What does watt do in speakers? Do all good speakers have a lot of watt?
Wattage is just a measurement of power, It won't tell you how loud the speakers can get. But yes, Higher wattage speakers tend to be of decent quality, as the components have to be able to handle that power well.
