I need help with my RAM issue and my monitor issue...
Solved by Chronified,
Put the RAM back in 1 stick at a time and try it with the GPU pulled since you have onboard graphics.
If it refuses to boot on the first stick with no GPU, pull it and try another stick, if both sticks are bad try a different slot, if they still don't work try a friends stick, if it still doesn't work you possibly have a bent CPU pin or a bad motherboard.
If using the onboard graphics and not the GPU works with all your RAM, you know your GPU is bad.
