650W Power Supply Enough?
Root
I'm wondering if my Corsair TX650M 80PLUS Bronze 650W power supply will handle my system that I want to upgrade. I'm looking to upgrade my video card from a GT 520 to a GTX 780. I calculated the minimum wattage I need using eXtreme Power Supply Calculator Lite. The minimum wattage I need is 635W and the recommended wattage is 685W, but I don't want to upgrade my power supply if I don't want to. Also, I have had this power supply for around 2 years now with average use. Average meaning it's on for a few hours a day but sometimes left running 24/7 for a few days (usually when I'm downloading something).
Will a 650W power supply be just enough for this? I wouldn't be upgrading anything else after the GTX 780 until March/April (2014) which is when I would get a new power supply.
Current PC Specs:
CPU: i5 3570K @ 4.2 GHz
Motherboard: Asus P8Z77-V PRO/THUNDERBOLT
RAM: Two Kingston HyperX Genesis 8GB (2x4GB) DDR3 1600MHz (16GB Total)
CPU Cooler: Noctua NH-D12 se2
Storage: Two Samsung 840 250GB SSD, Hitachi 250GB HDD, Seagate Barracuda 1TB HDD, external Hitachi 200GB HDD, external WD 250GB HDD
Case: Cooler Master HAF XB
Case Fans: Two Corsair AF120 Quiet Edition, Cooler Master Stock 120mm
PSU: Corsair TX650M 80PLUS Bronze 650W
GPU: GT 520 (Upgrading to Asus DirectCU II GTX 780)
Other: AVerMedia HD DVR internal capture card (To record console gameplay)
Keyboard: Cooler Master Storm MB24
Mouse: Cooler Master Storm MS2K (Always plugged in so the LED light always stays on)
(Both keyboard and mouse was from the Cooler Master CM Storm Devastator - MS2K & MB24 Gaming Keyboard and Gaming Mouse Combo)
Microphone: Blue Snowball (Always plugged in so always using power)
Webcam: Xbox Live Vision camera.
yes
ITX Monster: CPU: I5 4690K GPU: MSI 970 4G Mobo: Asus Formula VI Impact RAM: Kingston 8 GB 1600MHz PSU: Corsair RM 650 SSD: Crucial MX100 512 GB HDD: laptop drive 1TB Keyboard: logitech G710+ Mouse: Steelseries Rival Monitor: LG IPS 23" Case: Corsair 250D Cooling: H100i
Mobile: Phone: Broken HTC One (M7) Totaly Broken OnePlus ONE Samsung S6 32GB  :wub:  Tablet: Google Nexus 7 2013 edition
I think it should be fine if you want there is a website that shows you how much power you would need. The website is pcpartpicker.com if you go on it put your build in to the system build area and it should show you on the bottom right or the top right. But otherwise I think you should be fine.
Yes
CPUIntel 4670k  Motherboard - Gigabyte GA-Z87X-D3H  RAMKingston HyperX 8GB  GPU - EVGA 780  Case - Fractal Design Define R4    Storage - 2TB WD Black, Samsung 840 Evo 128GB     PSU - Corsair RM650  Display -  Benq XL2430T and Acer S235HL  Cooling - CM Hyper 212 Evo  Keyboard - Corsair K95  Mouse - Razer Deathadder  Sound - Sennheiser HD 558                                 Mic - Blue Snowball  Phone- OnePlus One  Tablet - Nvidia Shield
I used to run a 3930K and 2 Matrix 7970 Platinums with a 850w corsair but it pulled about 650 watts from the socket on full load.
