Which fan(s) is right for my radiator + case?
I'm currently wanting to get new fans for my case and I've been looking into Noctua fans since I've heard that they're pretty good.
I'm not sure which one to choose though, I have a 980Ti Hybrid and a H100i. I know that there are fans that do better at cooling with
radiators than others. So I guess I'm gonna be looking into buying two different types of fans, three for the radiators and the other two
for the front part of the case. I have the Corsair Graphite 780T if that helps by any chance.
I saw that the Noctua NF-F12 is a good radiator fan and the NF-P12 is good for more ventilation or whatnot. But still don't know which
fans I should buy, idk if I should be buying Noctua fans as a matter a fact.
If the NF-F12 is the one that I should buy then I would like to know what the difference is between these two fans. Thanks.
Noctua NF-F12 PWM Cooling Fan - http://www.amazon.com/Noctua-NF-F12-PWM-Cooling-Fan/dp/B00650P2ZC
Noctua SSO2 Bearing, Retail Cooling NF-F12 iPPC 2000 PWM - http://www.amazon.com/Bearing-NF-F12-iPPC-2000-PWM/dp/B00KFCR5BA
Yes, Noctua NF-F12 are great fans for radiators.
The difference between the two fans is that the iPPC fan is a industrial fan. It runs at a much higher speed and is also louder at that. But therefor it performs better. What you can do tho, is to turn down the speed manually in your motherboard BIOS.
The NF-P12 are just a cheaper version of the F12s. They don't have the rubber thingys at the corners.
