Help choosing cpu air cooler
Solved by WoodenMarker,
The first question and more important is if it 's going to fit the case and the second is if it is too much for an overclock of 4.5-4.6GHz.
All 3 coolers can fit.
The Dark Rock 3 is the only of the 3 that I would be confident in definitely being enough for 4.5-4.6ghz if the cpu is up for it. The other 2 would probably be enough for 4.4ghz+.
You need to quote a post or tag a member or else they won't get a notification you replied to them.
