Cluster computing and Render cluster help
Solved by AbsoluteFool,
7 hours ago, Mr. Cucumber said:@AbsoluteFool yes... Thanks for the help... I have some experience from Ubuntu and kali... From my college days ... And I have a fair collection of parts (motherboards cpus gpus rams I have 2 3 even 4 identical parts) so should I build two identical systems and learn how to use it? Will it even work?
That's what i would have done before i scale it up to 10 and more nodes. It's alot easier to make a two node cluster to get the basic idea, instead of jumping strait into a 10-12 node cluster.
If it will work depends entierly on you and the applications you want to run.
