6 minutes ago, Billy Pilgrim said:
Geforce Experience does not show it, however when it starts up the symbol appears in the upper right corner.
Try nVidia Control Panel.
DAC/AMPs:
Klipsch Heritage Headphone Amplifier
Headphones: Klipsch Heritage HP-3 Walnut, Meze 109 Pro, Beyerdynamic Amiron Home, Amiron Wireless Copper, Tygr 300R, DT880 600ohm Manufaktur, T90, Fidelio X2HR
CPU: Intel 4770, GPU: Asus RTX3080 TUF Gaming OC, Mobo: MSI Z87-G45, RAM: DDR3 16GB G.Skill, PC Case: Fractal Design R4 Black non-iglass, Monitor: BenQ GW2280
https://linustechtips.com/topic/998304-nvidia-driver-problems/#findComment-11994147
2 minutes ago, Billy Pilgrim said:
Where on the control panel?
Rightclick on desktop and you can see nVidia Control Panel and go to 3D configurations.
DAC/AMPs:
https://linustechtips.com/topic/998304-nvidia-driver-problems/#findComment-11994174
19 minutes ago, Billy Pilgrim said:
It does not appear under Manage 3D settings
It's not supposed too. You have to manually add the program so you can edit the settings.
https://linustechtips.com/topic/998304-nvidia-driver-problems/#findComment-11994248
Added it. How do I fix the blurriness?
https://linustechtips.com/topic/998304-nvidia-driver-problems/#findComment-11994389
Check if FXAA is enabled or some kind of AA techniques.
DAC/AMPs:
https://linustechtips.com/topic/998304-nvidia-driver-problems/#findComment-11994404
That fixed it. Thanks. However geforce experience shows an fps counter in the upper right corner, like I set it to in games. Is there a way I can disable this for just Atom?
https://linustechtips.com/topic/998304-nvidia-driver-problems/#findComment-11994418
You're welcome.
GeForce Experience is a bit of a shit program, I always untick it when installing nVidia drivers. Isn't there a hotkey for fps counter?
DAC/AMPs:
https://linustechtips.com/topic/998304-nvidia-driver-problems/#findComment-11994440
43 minutes ago, Billy Pilgrim said:
Is there a better program you could recommend?
A program to count FPS?
DAC/AMPs:
https://linustechtips.com/topic/998304-nvidia-driver-problems/#findComment-11995247
1 minute ago, Billy Pilgrim said:
Yes, and to take screenshots a videos
I can suggest MSI Afterburner. It gives you the abilities to take screenshots and capturing videos by pressing desired buttons.
I'd remove GeForce Experience. Most of the time it gives headache. It's good for nothing.
DAC/AMPs:
https://linustechtips.com/topic/998304-nvidia-driver-problems/#findComment-11995293
Can I use MSI afterburner without a single MSI part in my system?
https://linustechtips.com/topic/998304-nvidia-driver-problems/#findComment-11995328
Yes. I have the Gigabyte GPU so you don't have to have a MSI part in your system.
DAC/AMPs:
https://linustechtips.com/topic/998304-nvidia-driver-problems/#findComment-11995341
Glad to help.
DAC/AMPs:
https://linustechtips.com/topic/998304-nvidia-driver-problems/#findComment-11995351
