Okay, so long story short, I am planning for yet another build for the upcoming Black Friday and Cyber Monday. So far, I have my potential build but I would like to see if this is a good build. I have a budget of 1000 dollars, and plan on using it for college work and gaming (not gaming extremest).
The dream build consisted of the following:
CPU: Intel i5-7400-$216.99
MotherBoard: GIGABYTE GA-Z270P-D3-$59.99
GPU: Sapphire PULSE Radeon RX 570 4GB-$174.99
RAM: G.SKILL Aegis 16GB-$104.99
PSU: SeaSonic M12II 620 Bronze-$55.06
STORAGE: SAMSUNG 860 EVO Series 2.5" 1TB-$127.98
PC CASE: MasterBox Q300L-$39.99
MONITOR: Acer KG271 bmiix 27"-$141.49
TOTAL COST: 921.48
This is the dream build that I have. If there are any suggestions that could better my build, please do say before Black Friday. I look forward to any suggestions!!!
https://linustechtips.com/topic/997089-2018-pc-build-help/
What is your location?
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
https://linustechtips.com/topic/997089-2018-pc-build-help/#findComment-11983919
Not really.
  • You're using an ancient processor. Go for something 8th gen.
  • No need to use a Z series motherboard with a locked processor (though the price isn't terrible).
  • Get a better PSU; check the LTT PSU tier list.
  • I wouldn't get a 27" 1080p monitor.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/997089-2018-pc-build-help/#findComment-11983927
Build A:
Or Build B:
You can also look at getting something like a used 980 Ti. It will handily beat an RX 580 or GTX 1060, and it's about the same price (~$220-250)
https://linustechtips.com/topic/997089-2018-pc-build-help/#findComment-11983951
I see Kaby Lake, I fail the list. Atm budget users should get Ryzen CPUs, specifically (for $800+) I'll recommend the Ryzen 5 1600/2600.
Also the PSU, isn't good by 2018 standards. Get something tier 3 or higher. 450w PSUs are more than capable of powering new mid range hardware
Desktop benching:
https://linustechtips.com/topic/997089-2018-pc-build-help/#findComment-11983955
