Help me upgrade my System
Solved by Cereal5,
i7-4770 or 4790 (120-150 Euros)
A new PSU like this, this, or this.
And finally an RX 580 like this one.
There are other 580s that aren't bright blue, but that is the cheapest 8GB model, and it's pretty good at that. All of those parts should run you anywhere from 350-400 Euros, and should last you a while to come at 1080p.
You can measure your RAM usage while playing games, and if you are running out, then I would recommend getting a 2x8GB kit or a 4x4 GB kit, so you have 16 instead of 8. However, you most likely don't need to upgrade your RAM.
