Even if it does your thermals will likely be terrible. You can always get the bracket made by cooler master
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
13 hours ago, Gwingle said:
Does anyone know if the Cooler Master MasterBox MB530P supports vertical GPU mounting?
Not natively no. You'd normally see mounts for those here:
As @Cereal5 mentioned, native mounts that put the GPU in this location often choke Air cooled GPU's of air which can cause the GPU to overheat and throttle back, meaning a loss in FPS! I would recommend one of Coolermaster's own vertical GPU mounts or one from a third party like @CableMod which use the PCI-E slots to mount a vertical bracket, which is further away from the side panel which is good for 99% of the cards on the market.
@Gwingle check out the CableMod vertical PCI-E bracket. Thermals won't suffer as they do with traditional mounts as we positioned this properly away from the side panel window to ensure airflow is still properly distributed to the card as mentioned above. Pic for reference.
