Best Mobo VRM HELP!
Go to solution Solved by maartendc,
I have been researching this exact thing:
Yes the Aorus b450 itx board gets hot in the VRM area, not recommended. Some reviews have shown this.
MSI b450 itx board also has 4+2 VRM, so not much better probably.
Arock b450 itx board has 6+2, but it is a doubled 3 phase for the CPU. Reviews (Tweaktown) have shown excellent thermals on this VRM, heatsink looks small but performs wel. Not as good as a true 6 phase vrm, but the heat is spread over more phases, so looks to perform well.
Asus b450 strix itx board is the only board with a TRUE 6 phase on the cpu, AFAIK. Don't know if it is worth the extra money though ($150 vs $90 for the Asrock on sale at Newegg).
Id go for the Asrock, that is what I am getting. Reviews say it is really good, also in the VRM dept. Has better features than Giga yte and MSI too. Can do some OC'ing on it, although the Asus is probably slightly better.
Good luck!
I bought a gigabyte B450 I Aurous and a ryzen 2700.
After doing some research I learned that the VRMs on the board are not good for CPUs 6-8 cores when overclocking and will get really hot. I haven't opened anything yet so I can still return. I was wondering what would be the best Mobo to get for 2nd gen ryzen processors. It needs to be ryzen 2000 ready because I do not have a processor I can do a bios update with. Was wondering what you think?
All feedback appreciated!
Thanks!
https://linustechtips.com/topic/994883-best-mobo-vrm-help/
Which Aorus? chances are it's actually fine for overclocking a 6 or 8 core.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/994883-best-mobo-vrm-help/#findComment-11965602
How much can you spend then?
All Aorus B450 suck equally.
Desktop benching:
https://linustechtips.com/topic/994883-best-mobo-vrm-help/#findComment-11965612
4 minutes ago, CamIndigo1 said:
$150 usd range, but I am flexible
Does it NEED to be mini-ITX form factor, or will regular ATX or mATX be okay?
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/994883-best-mobo-vrm-help/#findComment-11965680
$164 Asrock X370 Taichi is as good as a deal gets atm without going too far off the budget, but if you can the $180 Asus X370 Crosshair VI Hero is an even better deal. Both boards can flash their BIOSes without a CPU as long as you have a USB drive holding the new BIOS.
Oh wait that's mITX. Then it's down to the Asrock B450 Gaming ITX or Asus B450-I. The Asrock one is good enough, while Asus performs very well. It's $90 vs $150 though
Desktop benching:
https://linustechtips.com/topic/994883-best-mobo-vrm-help/#findComment-11965687
I forgot to mention in the post, I'm in a mini itx, needs to be a sff board
https://linustechtips.com/topic/994883-best-mobo-vrm-help/#findComment-11965710
I updated the last post, refresh the page so it shows up
Desktop benching:
https://linustechtips.com/topic/994883-best-mobo-vrm-help/#findComment-11965712
And do both of these have better VRMs than what the Auros has? If I can save some money, I'll prob go ASRock, but if the Asus is worth it, then I'll go for Asus!
https://linustechtips.com/topic/994883-best-mobo-vrm-help/#findComment-11965741
Yes both better than Aorus, but on Asrock it's a marginal improvement. Asus one is worth the money here, if you can spend it that is.
Desktop benching:
https://linustechtips.com/topic/994883-best-mobo-vrm-help/#findComment-11965756
10 minutes ago, CamIndigo1 said:
I totally forgot to mention in the post, yes I am in a mini itx case.
In that situation, the Gigabyte B450 I Arous should still be enough to handle medium overclocks.
The AsRock Fatal1ty B450 Gaming-ITX is another decent option.
6 + 2 VRM  (I don't think it's running doublers, but don't quote me on that) ... but it looks like it uses an even smaller heatsink on VRMs.
MSi B450I Gaming Plus AC is another option, but it looks like it is running a similar 4+2 VRM system as the Gigabyte board.
Other then those, it would be the ASUS B450 and X470 ROG STriX motherboards.
With all this said, CPU + system cooling would be another limitation.
You have limited airflow / case fan mounting options with an mini-ITX build, so you can only overclock so far.
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
https://linustechtips.com/topic/994883-best-mobo-vrm-help/#findComment-11965760
Good luck!
https://linustechtips.com/topic/994883-best-mobo-vrm-help/#findComment-11966074
