Water block for Gigabyte 1080 ti Turbo
Gleb K
Go to solution Solved by Gleb K,
The PCB is extremely similar to the gaming OC card , it even has 3 fan headers ; however, the layout of the left (io) side is a little different. Here are some pictures
I hope this is useful for someone :)
Hello,
    I have been looking for a water block for the Gigabyte 1080 Ti Turbo for quiet some time and only found this: https://www.amazon.com/Bykski-Cooling-Gigabyte-GTX1080Ti-Gaming/dp/B071RKBZM9 . However I have heard during my searches that the Gigabyte 1080 Ti Gaming OC has the same PCB and therefore was wondering if this water block would work: http://www.phanteks.com/PH-GB1080TiGB.html .
i7 8700K CPU | Gigabyte 1080 TI Turbo Graphics Card | Asus Z370-A Motherboard | 2 x 16GB Vengeance LPX Memory |  Samsung 1TB 970 Pro SSD | WD Red 6TB & WD Green 3TB HDDs | Be Quiet! Dark Base Pro 900 rev.2 Case | EK Monoblock + Bykski Graphics card Waterblocks EK 420 PE + 420 CE Radiators | 6 EK Furious Vardar EVO 140 BB Fans |  Enermax Neochanger 200ml Reservoir & pump
not sure if it hurts waterblock compatibility, but their PCBs are certainly different. the 3 fan card has 8+2 VRM phase design while Turbo follows the reference 5+1
Desktop benching:
How could I find out whether it fits or not (without buying it)? Or should I just buy what I found before.
tbh I'd just ditch the idea of full cover blocks and use AIO brackets like the NZXT G12 or Corsair HG10, plus a liquid AIO CPU cooler instead. The phanteks one seem to work as well though
Desktop benching:
Post back and let us know too. The turbo doesnt have DVI but the Gaming one does, so they cant have exactly the same PCB, but it may be similar enough
I cant find any pictures of the PCB on the net though.....
  • 2 weeks later...
Just to let you guys know Phanteks replied "...You would need to check yourself if the Gigabyte 1080TI Turbo uses the same PCB layout as the G1080TI Gigabyte Gaming OC edition." Highly useless so I think I'll just buy whatever is cheaper, I'll let you know if the one I buy fits or not.
Ok, I was randomly browsing the internet and I found the an image of the Gigabyte 1080 TI Gaming OC and they look kind of the same however I'm not exactly sure if the two waterblocks have the same undersides...(if they do then I guess the Phanteks fits on the Turbo card). What do you think, are the two waterblocks / PCBs the same?
Here are some images:
Gigabyte Geforce GTX 1080 TI Gaming OC:
Gigabyte Geforce GTX 1080 TI Turbo:
Underside of Phanteks waterblock:
Underside of Bykski waterblock:
I am 100% sure that this is an asus turbo card and not a gigabyte turbo card. I recognize the chokes.
Uhm, the website says it is gigabyte...
2 minutes ago, For Science! said:
No, the picture of the pcb
I am dumb, it even says "ASUS" near the PCIe connection xD
Yep. Knew it. Whoever posted the picture about the pcb doesnt know anything. They just assumed two "turbo" cards are the same.
https://www.ekwb.com/configurator/step1_complist?gpu_gpus=3790
I think I'll just go with Bykski because I am having trouble finding the phanteks on amazon, ebay or newegg anyway...
Take a snap of the pcb when you install the block! They two of them do look quite similar but the bykski looks like it makes more contact than the phanteks one.
Ok, I'll post the PCB in this thread in like 2 weeks or so.
  • 3 weeks later...
Just realised the title was wrong (it said 108 ti turbo)
  • 1 month later...
Hello
Have found water block what fits?
I have 2 x turbos and i want to water it but only full block. Please help me
Installed the Bykski block last weekend on my GV-N108TTURBO-11GD.
Fits good and has more coverage than the Phanteks as others have pointed out.
Temps have been as low as 23 at idle and 42 under full load.
Thanks for confirming for others too! I have only just started running my loop but so far it's been great for me too.
