Can I use a lower wattage power supply for my Laptop
Solved by Fasauceome,
What you want for a charger is to have the same voltage. If it were a power supply, you would need a higher or equal current, but the lower power charger should just charge slowly
Featured Topics
wolfgangam ·
Posted in Windows2 -
7
3
2
Joseph_Stalin ·
Posted in CPUs, Motherboards, and Memory4 -
Evan37 ·
Posted in New Builds and Planning5 -
IlanMS ·
Posted in Peripherals9 -
Frossty ·
Posted in Graphics Cards9
