Help- Gygabyte ultra Z390 boot looping
I installed a 9900k on the GYGABYTE Z390 ultra motherboard. When it posted the option to go into bios the keyboard would not work. I tried changing it and only leaving the keyboard and hdmi cable pluged in. That did not help. I tried resetting CMOS but now it's stuck on error code 60 before looping. Error code 60 is DXE core is started. I tried resetting the CMOS again and trying to use only 1 stick of ram but nothing.
Edit- I left it running while I was away and when I came back the buos was loaded in. Updated it and now it seems to be working fine
Edited by lmmersion
Is the CPU pump getting warm? Maybe hot? Check the piping right where it connects to the cpu block. Have you tested multiple RAM sticks, one at a time, in every RAM slot?
Have you tried with no GPU installed? Have you Tried with no RAM installed at all? Is the BIOS updated, maybe its required to support the new CPU (you would install an older CPU and update BIOS, then install the new chip). If none of that works/applies, maybe checking the motherboard for bent pins is neccisary (huge pain to take off cooler and CPU though).
Gaming - Ryzen 5800X3D | 64GB 3200mhz  MSI 6900 XT Mini-ITX SFF Build
Home Server (Unraid OS) - Ryzen 2700x | 48GB 3200mhz |  EVGA 1060 6GB | 6TB SSD Cache [3x2TB] 66TB HDD [11x6TB]
Try reseating the CPU, especially since after leaving it a while it finally did go in.
Your cooler/cpu block might be unevenly tightened, not tightened enough, tightened too much, or even a CPU pad could be making poor contact.
A BIOS update might also be a good idea since the 9900k is newer than the Gigabyte Z390 board. While, yes, it's compatible with the chipset, since the board is older than the CPU it might/will need a BIOS update to be /officially/ supported and make it stable.
(I had to do the same thing to my 870A chipset using an old Athlon II x2 to get my FX 8350 working with the board)
My rig:
CPU: Ryzen 5 3600 3.6Ghz, OC'ed to 4.2Ghz all core @ 1.25v + Corsair H60 120mm AIO
MB: Gigabyte B450 I Aorus Pro WiFi
RAM: Kingston Fury Beast RGB 32GB (2x16GB) 3600mhz CL16 (1-to-1 Infinity Fabric enabled)
GPU: Gigabyte RTX 2080 Super
*bought for $200 CAD off a friend who needed an RTX 3080, price was my reward.
CASE: InWinn A1 Plus in White with included 600w gold sfx PSU and included custom length cables
DISPLAY: 3x 20" AOC 1080p 60hz 4ms ,  32" RCA 1080p/60hz TV mounted above, all on a single arm.
Storage: C : 1TB WD Blue NVMe      D : 2TB Barracuda      E: 240GB Kingston V300 (scratch drive)
NAS: 240GB Kingston A400 + 6x 10+ year old 700GB Barracuda drives in my old FX8350+8GB DDR3 system
Logitech G15 1st Gen + Logitech G602 Wireless
Steam Controller +  Elite Series 2 controller + Logitech G29 Racing Wheel + Wingman Extreme Digital 3D Flight Stick
Sennheiser HD 4.40 Headphones + Pixel Buds 2 + Logitech Z213 2.1 Speakers
My Girlfriends Weeb-Ass Rig:
Razer Blade Pro 17 2020
10th Gen i7 10875H 8c/16t @5.1ghz
17.3" 1080p 300Hz 100% sRGB, factory calibrated, 6mm bezel
RTX 2070 Max-Q 8GB
512GB generic NVMe
16GB (2x8GB) DDR4 3200Mhz
Wireless-AX201 (802.11a/b/g/n/ac/ax), Bluetooth® 5.1, 2.5Gbit Ethernet
70.5 Whr Battery
Razer Huntsman Quartz, Razer Balistic Quartz, Razer Kraken Quartz Kitty Heaphones
*deep breath*
Razer Raptor 27" monitor, IT'S BEAUTIFUL.
eh, first boots are bound to take longer than usual amount of time
Desktop benching:
