A few days ago, I finally upgraded to NVMe. I got a Samsung 970 Evo 250GB. I was so blown away by it, that today I bought a 970 Evo 1TB.
One problem tho, those things get HOT af. I don't like anything in my PC reaching 75c every now and again. I was wondering what I can do about that.
There is a sticker on it, which might contribute to the temp, but I think heat sink would be better than just removing the sticker.
So, do you have a 970 Evo? How's your temp? Thoughts on heat sink? Any models of that you've used before?
https://linustechtips.com/topic/992010-nvme-temperature-help/
I've got an 960evo and the sticker on it actually has some copper wires in it afaik which help to dissipate the heat. Mines got the motherboard heatsink in it though which keeps it around 60°C iirc. There are other third party heatsinks for nvme though, if you really can't stand it being 75°C.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/992010-nvme-temperature-help/#findComment-11939019
I got the OEM version - PM981, in my lappy. It does run very hot - under 100C after prolonged writes. I installed a M.2 heatsink with 2mm thermal pad (bought for under 3 bucks), now it runs cooler now. It will still throttle in long period of heavy writes, nevertheless the improvement is there. I didn't remove the sticker. I removed the original metal heatsink+thermal pad on the bottom chassis which does little to nothing to cool the SSD.
It's important to keep the controller cool for longevity
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/992010-nvme-temperature-help/#findComment-11939047
I have a ssd nvme Corsair MP500, when it is not in use it reaches 48-50 C. When I use it reaches 60-65C, it does not have a heatsink, but I think it takes some air from the CPU Fan.
I find normal temperatures for the performance provided by these components.
If I had a motherboard with disiators for M2, I would remove the label and very carefully apply thermal paste.
https://linustechtips.com/topic/992010-nvme-temperature-help/#findComment-11939403
Maybe something like this?
https://www.amazon.com/XPG-Storm-Cooling-Heatsink-ASTORM-C/dp/B077SSV15R
Or cutting a hole in the side of case with metal cutters and placing a 120 mm fan that is zip tied to the case there to blow air on it or pull the hot air away?
Current computers:
Primary Computer (In Progress):
SUBJECT TO CHANGE
CASE: ROSEWIL THOR V2 Black
CPU:
Motherboard:
GPU: SAPPHIRE VEGA 56 -TBU RTX 2070 SUPER
RAM: 48 GB CORSAIR VENGEANCE LPX
PSU: SEASONIC PRIME 1300 W GOLD
STORAGE: 4x SEAGATE EXOS 4TB | Sans Digital HDD 5-Bay Rack | Sisun IDE SATA HDD Docking Station
SOUND SYSTEM: Logitech Z506 Surround Sound via Vantec USB External 7.1 Channel Audio Adapter
MOUSE: 16000DPI GAMING MOUSE
KEYBOARD: -PENDING-
MONITOR: -PENDING- AOC AGON AG241QX 24" -PENDING-
COOLING:  CPU: Noctua NH-D15 -3x NF-F12 Fan MOD || 10-12X NF-F12 || EXHAUST: 3x NA-A12x25
LAST UPDATED 4/29/20
Secondary Computer:
CPU: AMD FX-8370 Black Edition
Motherboard: ASUS M5A97 R2.0
GPU: Zotac GeForce GTX 970 AMP! Omega Core Edition
RAM: 24GB Kingston HyperX Savage 1600MHz DDR3
PSU: Antec High Current Gamer HCG-900W
STORAGE: 5x Western Digital Black 2TB - WD2003FZEX | Sans Digital HDD 5-Bay Rack | Sisun IDE SATA HDD Docking Station
MOUSE: PUREX 2400 DPI Wired Laser Gaming Mouse
KEYBOARD: DBPOWER 104 Key -3 Backlit -I KNOW! Linus doesn't approve -I have glued it to the desk and it works well for my needs.
MONITOR: ASUS VS247H-P 24 Inch
COOLING: CPU: Noctua NH-D14 -3x NF-F12 Fan MOD || 10-12X NF-F12 || EXHAUST: 3x NA-A12x25
GRAPHICS: 2x NF12s fans on graphics card + 2x NF-F12s & 1x NA-A12x25 in Fan box | 1x Vantec SP-FC70-BL Spectrum System Fan Cards
https://linustechtips.com/topic/992010-nvme-temperature-help/#findComment-11940624
