It runs at 2400.
https://linustechtips.com/topic/990317-mixing-ram-speed/#findComment-11924225
3 minutes ago, Lord Letto said:
This, it runs at the slower speed & looser timeings of the 2.
you will always run at the slower ram speed. also, dont forget to enable XMP!!! try overclocking the 2400 ram to about 2666 so all sticks can run at 2666. also, if the ram cannot overclock, try tightening the timings. that gives you free performance with no cost (not even more power draw).
https://linustechtips.com/topic/990317-mixing-ram-speed/#findComment-11924278
