Folding Client Remote Access Stuck at Connecting
Solved by Dissitesuxba11s,
@Gorgon I actually found out what the issue was: some of the inbound rules for "fahclient" in the firewall had the Action in General settings set to "Allow the connection of it is secure." Changing them to "Allow the connection" let me connect successfully
Either way, thank you for bearing with me and helping me diagnose the problem. Now I don't have to go down two floors to see how the basement PC is doing.
EDIT: I feel bad that my post is the solution.
