Posted January 7, 2014 I put this in general discussion because I'm not exactly sure where to put it, I'm not really asking for advice on air cooling or watercooling. I was thinking about having a nice air cooler (NH-D14/Silver Arrow?), and a watercooling loop just for the GPUs. I'm asking this because I do have a watercooling kit that I used for a while (pump has some issues, I'll get it replaced) with a 360mm rad. The waterblock is really scratched up (an unnamed person put it in a box of fan screws), and I don't have most of the CPU mounting hardware. My CPU is also a 3930k @ 4.5GHz, which would really heat up the loop. Is this a good/bad idea? If anyone in the forum has a AC+WC setup, any input is appreciated. Spoiler Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 7, 2014 It is probably manageable, but it would look weird lol. I would put a H220 and expand it with your 360 if the case has the room. Personal Rig i7 4790K | Asus Z97I-WiFi | CM 280L | Sapphire R9 290X Tri-X | Kingston ValueRAM 2 x 8GB | 128GB Samsung 840 Pro | 2TB Seagate SSHD | Seasonic Platinium 660W | Bitfenix Prodigy Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 7, 2014 Author It is probably manageable, but it would look weird lol. I would put a H220 and expand it with your 360 if the case has the room. Do you think the H220 could push a 360+240, CPU and 2 GPUs? Seems like a little much. Spoiler Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 7, 2014 Do you think the H220 could push a 360+240, CPU and 2 GPUs? Seems like a little much. Worse case scenario, let us say the CPU needs the 360 to be cool. Even with that, the 2 GPUs can go on with the 240 rads happily while being cooled (See people using 120 AIOs with Kraken G10s on 290s) Personal Rig i7 4790K | Asus Z97I-WiFi | CM 280L | Sapphire R9 290X Tri-X | Kingston ValueRAM 2 x 8GB | 128GB Samsung 840 Pro | 2TB Seagate SSHD | Seasonic Platinium 660W | Bitfenix Prodigy Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 7, 2014 Do you think the H220 could push a 360+240, CPU and 2 GPUs? Seems like a little much. it can, swiftech does it in their showcase of one of linus' videos of last years ces Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 7, 2014 AC+WC setup might as well just use a G10(s) and H55(s) + air If you do a loop for the GPU alone you can throw the CPU in while you're at it since all it needs is a 40$ rad and a whatever block. If your block isn't scratched to hell, you can probably repair most of it. Error: 410 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
