Cooler Master MasterLiquid ML240L RGB
Solved by WoodenMarker,
1 minute ago, Ottens238 said:Just to be clear, the Cooler is great but a little bit loud, am I right?
Does it stay around 80 degrees Celsius while probably overclocked to 4.6GHz or higher, during load?
Temps will depend on several factors including how much voltage you'll need for the oc. At worst, it shouldn't be any more than 80-90c at load.
Featured Topics
bensinspade ·
Posted in Graphics Cards1 -
CloseTheDoor ·
Posted in New Builds and Planning6 -
pchelp ·
Posted in CPUs, Motherboards, and Memory11 -
pontikos ·
Posted in Troubleshooting2 -
7
wolfgangam ·
Posted in Windows3 -
12
