Spectre build: Oil Slick
frankengun
So I've been hoarding parts since January when I preordered the Singularity Cases Spectre case. Got it a week ago or so and immediately threw everything into it over the course of four days, so apologies for no lead time.
Parts:
8700k w/ EK Spupremacy Nickel block
NZXT N7 Z370 (I know already, please stop chastising me about the stupid mobo)
Nvidia RTX 2080 Ti w/EK Vector RGB block
EVGA 1000W Supernova P2 PSU w/ custom cables by MainFrame Customs
2x WD Black m.2 500GB SSD
3x Mushkin Reactor 1TB 2.5" SSD
Singularity Computers Spectre case in black, Protium pump/res combo
Mayhems X1 Black coolant
Bitspower plated brass tubing, 16mm
Assload of fittings by Monsoon, Touchaqua, Barrow, and Bitspower
6x In Win Polaris Aluminum RGB 120mm fans installed on 2x EK 360mm thin rads
The pile of parts, waiting only on the case and GPU to come in.
Welp there's one of em.
The block and backplate had been sitting in my office for over a week waiting for the stupid thing.
And then the Spectre came in. I did a livestream of the unboxing in a Facebook PC building group so I don't have pics of the packaging, but it was well packed and annoying. Here's a pic of the custom engraving they did with a design I sent them.
And so I started building.
Time to pressure test these looopty loops
I used this doohicky. Worked pretty well for a decay test after I disassembled it and fixed all the leaks in the device itself.
The end result was this. I'm really happy with how it turned out. I spent my PC building budget for the next three years though, so no more new PCs for me for awhile.
  • 6 months later...
  • 1 year later...
The manifold screws starting coming loose at the bottom, which let fluid leak between the layers of acrylic. So a complete disassembly, cleaning and reassembly was in order. I went ahead and did a lot of maintenance to it, upgraded to an MSI Z370 Godlike mobo, changed the tube routes again, and ditched the RAM block for some Dominator Platinums. Also decided to ditch the black coolant and go with Koolance UV green, which reacts quite well with purple backlighting on the manifold.
My daughter takes over the battlestation regularly.
Cat Tax
Looks good!
I really like the tube routes you changed in the second iteration...i wasnt a fan of the first iteration, it looked too messy to me.
Have you thought of building a custom harness? Since this case has a higher visibility on the power cables, there is a higher focus on bundles that would normally be hidden behind the mobo tray.
Also, have you thought of maybe a cover over the rear of the case (rear I/O)? I think it would sharpen the look a lot with that small detail.
On 5/23/2020 at 11:13 AM, kkpatel87 said:
Looks good!
Thank you, I'm a fan of the simpler layout myself. What do you mean by custom harness?
  • 3 weeks later...
Upgraded to a 9900k I've had laying around for a couple weeks and redid a few tube runs.
  • 2 weeks later...
One thing I like about having neutral colored cables is I can dick around with the RGB and it mostly looks all good.
