Help with Fallout 4
Solved by Acid Panda,
if you crashing its likely you have a conflict with some of the mods.
also if you running some sketch parts then it might be that the usage of ram is too much for the system so results in a crash.
more mods use more ram and 8gb i believe is the advised amount so if you passed that then problems can occur.
see if you can also alloate more ram to the game it might help with the overhead
