How to evenly split memory to 2 Hard Drives
Solved by X1XNobleX1X,
Will it change something in my system? And is there any chance of my data getting lost? (Thank you for your help by the way)
To run drives in JBOD, you need to set you motherboard in Raid mode (in the bios)!
And then as the rig boots. You see it say something like press "Ctrl+I" to enter Raid setup!
You go into there, and make an Array and where it says what type of raid. You choose JBOD
But the trouble is! Going from IDE or AHCI mode to Raid will most likely mean you have to re-install the OS!
Although you might be OK going from AHCI to Raid! I'm not sure
But anyway, JBOD is in the Raid menu
