Don't turn it on. Unplug everything and take it to a repair shop.
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
https://linustechtips.com/topic/982793-pc-repair-pls-help/#findComment-11853104
Do what Mello and bleedblue said, but my recommendation is when taking the side panel off, maybe look for the source of the smell. If exploring deeper for the source requires unlplugging cables/dismantling the pc, then don't do those two things. Just put the panel back on and get it looked at like bleedblue said.
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
https://linustechtips.com/topic/982793-pc-repair-pls-help/#findComment-11853121
5 hours ago, IanHaines said:
Hi Im sorry for my poor grammar but im only 11 , my parents bought a custom pc for my birthday and its making strange electrical sounds and it smells strangely (kind of a burnt electrical smell) , it failed to POST for a few times before turning on  , what should I do guys?
Definitely look for the part, I believe that u have a bad power supply, do u have a tinny one?
https://linustechtips.com/topic/982793-pc-repair-pls-help/#findComment-11853605
