Z77-a motherboard (help needed)
I need some assistance, I had an unexpected error about 2 days ago. My computer black screened and rebooted and before it got into windows it did it one more time. This time it popped up saying a surge was detected, surge was caused by an unstable power supply unit. I bought a new power supply unit, installed it today and I have the same problem.
what model are these?
Desktop benching:
System
-z77-a rev. 1.01 asus motherboard
-i5 3570k
-2x4gb ddr3 gskillee
-1x4gb ddr3 kingston
-both powersupply are 850w
  -thermaltake bronze
  -evga gold
-1050 ti asus strix
maybe something shorting? Also check below the motherboard to make sure the standoffs are properly installed and there's nothing underneath the motherboard between the case.
Desktop benching:
I removed the motherboard from the case thinking that might of been the problem, it seems my 12 volt rail keep a climbing and the system shuts off at 14v on the 12v rail
I also checked the motherboard for bloated capacitors, burn marks, corrosion, and marks that would of been caused by arcing.
I'm guessing i need to see about doing a bios update might fix it.
New bios didn't help fix the issue, I'm just going to buy a new/old motherboard to replace this current one. I'm stuck in a pickle, I don't have enough to upgrade to a new platform. Thanks @jurrunio for trying to help me out, it is very much appreciated!
