got a new SSD, I wasnt wanting to clone the drive over and just do a fresh Windows 10 install, what would be the best way to go about this, is there going to be windows activation issues? I havent done this operation on W10 before, if I change my video card at the same time as I put the new SSD in will it be more likely to cause issues with activation? Should I install windows with my current card, activate, shut down and then swap cards?
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
https://linustechtips.com/topic/982217-changing-w10-os-drive/
https://www.howtogeek.com/224342/how-to-clean-install-windows-10/
It will activate itself, you don't need to do anything.
https://linustechtips.com/topic/982217-changing-w10-os-drive/#findComment-11848622
8 minutes ago, Electronics Wizardy said:
Just put windows 10 installer on a usb and then boot from it. In unplug all other drives when doing this.
How is windows activated on your system?
Dunno what you mean by "how" it was a windows 8.1 upgrade and ive reformated before and changed hardware and reactivated it fine, just never while changing anything more than 1 hardware component and never on a new storage device than it was on before.
System Specs
https://linustechtips.com/topic/982217-changing-w10-os-drive/#findComment-11848626
The only component change that will deactivate your windows copy is the motherboard.
If you ever need to change your motherboard then just do this https://support.microsoft.com/en-ca/help/20530/windows-10-reactivating-after-hardware-change
https://linustechtips.com/topic/982217-changing-w10-os-drive/#findComment-11848636
