hi all
i got a new pc built it and everything working fine but lately i noticed that some parts of my case got weak electric flow (screws-io shield-gpu shield)
it is nothing serious it just tingle a bit i live in an old house i got no grounding and using 2 prongs outlets
i checked mobo to see if i installed it right and no problems but i noticed that standoffs also got that weak electric current
so could the mobo be responsible for this as it is connected to case through those metal standoffs
i have been running this pc for about a week nearly 24/7 with no problems at all but i want to know if this ungrounded case can cause damage to my components
thanks in advance
https://linustechtips.com/topic/982149-my-case-got-electric-current/
19 minutes ago, asd2000 said:
hi all
thanks in advance
This is a serious issue check the psu the psu is already grounded since it has a third prong. Make sure there is nothing out of the order
1 minute ago, Lordclouds said:
This is a serious issue check the psu the psu is already grounded due for the third prong. Make sure there is nothing out of the order
psu power cable is also 2 prongs
i checked to see if it is leaking power but when i touch it i feel nothing
it is BitFenix Whisper 650w so i think it is a good quality one
i suspect that mobo is making electricity flow to the case through metal standoffs and i feel it cause the case is ungrounded so current stays in case
Did you use the motherboard stands?
Just now, asd2000 said:
i got no ground power cable for my house
Image result for 2 prong us power cord wiring
The neutral is a return and sorta functions as a ground in two prong systems. It's not a proper ground lug, but it allows current to flow. Just touching  your computer case, you shouldn't be able to feel any current. Maybe you're feeling a static shock?
ASU
it isn't static i think
it is a continuous current i would put my finger on a case screw for as much time and still feel it
but as i said before i have no problems with my system till now
Is your PC set up on a desk? Do you have a lot of carpet? When you touch your internal, are you wearing socks on a carpet flooring? Is the outlet old?
You shouldn't be able to feel anything if you're just touching one point on the computer unless some how ac is connected to your case. That would cause other problems befusee you would connect some voltage source directly to ground in your motherboard through the standoffs which would fry something. I don't want to discredit what you're saying, but what you're describing sounds impossible to my knowledge of electronics.
ASU
my pc is on desk i don't have a lot of carpet i can feel the current when i am bare footed standing on tiles and yes the outlet is old and the house doesn't have grounding
1 hour ago, jonnyGURU said:
No. Unless you have a surge come in.  Without earth ground, a surge could kill everything.
thanks for your help sir
so if it is not possible to rewire the house and make it grounded
is there any easy way to ground my case and somehow protect it ?
Then you should ask an electrician to look at your installation and check if the ground is present.
Because either the Ground is not present or you have a fault voltage due to a break in the line.
"Hell is full of good meanings, but Heaven is full of good works"
