My parts:
CPU: i5 4670K
Case: Corsair Vengeance C70
CPU cooler: Corsair H100i
Graphics card: 2X EVGA GeForce GTX 770 Dual SC ACX 4GB
Storage: Samsung 840 EVO Series 250GB SSD
Storage: Seagate Barracuda 2TB
RAM: Corsair Vengeance 8GB (2x4GB) DDR3
Motherboard: Gigabyte G1 Sniper Z87
Power Supply: Corsair AX860
Price: $2500 Australian (ish)
i dont mind spending the cash, but any advice?
https://linustechtips.com/topic/98158-my-first-build/
looks good to me! :)
Edit: what res are u playing on? if 1080p you dont really need 4gb 770. They cant use their 4gb vram anyways.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/98158-my-first-build/#findComment-1313106
Hi and Welcome to the Linus Tech Tips Forum :)
Although dual 770's outperform a single 780/780 Ti the scaling might not be too great. Other than that very nice.
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
https://linustechtips.com/topic/98158-my-first-build/#findComment-1313115
Yes, I'd agree on this. If you need more than 2GB of VRAM, I wouldn't go with 4GB GTX 770's. They only have a 256 bit bus, you'd be better off going with a single higher end card. Honestly dual cards aren't really worth it unless your willing to mess around with drivers. Some games won't support dual cards either. Go with a single R9  290X or GTX 780 Ti (if you can afford it)
A single 780 Ti would probably perform equally in most games, and actually outperform it in some cases given that scaling will vary from game to game, and in some the OP may only see a 20% increase in performance over a single 770.
CPU: 5930K @ 4.5GHz | GPU: Zotac GTX 980Ti AMP! Extreme edition @ 1503MHz/7400MHz | RAM: 16GB Corsair Dom Plat @ 2667MHz CAS 13 | Motherboard: Asus X99 Sabertooth | Boot Drive: 400GB Intel 750 Series NVMe SSD | PSU: Corsair HX1000i | Monitor: Dell U2713HM 1440p monitor
https://linustechtips.com/topic/98158-my-first-build/#findComment-1313137
if money is not the issue why not get the best GPU possible now so that you won't be needing to upgrade anytime soon? i say a 290x or a 780Ti ?
  • CPU i5 3570k - 4.0 Ghz | Motherboard Intel DZ77SL50K | RAM Corsair Vengeance 4GB 1600 BUS DDR3 4GBx1 | GPU 2x Sparkle GTX 570 OC editionCase CM 370 EliteStorage Seagate 1TB 3.5" SATA HARD DRIVE 64MB CACHEPSU Cooler Master GX series 550W (80+ bronze)Display(s) Samsung 46' series 5 TV(1080p), Dell 20' (1280x1024)Cooling 3x Corsair SP120 QUIET EDITION HIGH STATIC PRESSURE 120MM FAN TWIN PACKKeyboard DELL original default keyboardMouse A4 Tech x2 800dpi | Sound On board~!
https://linustechtips.com/topic/98158-my-first-build/#findComment-1313138
Also, going for dual GPU's before getting an i7 makes no sense in my mind.
https://linustechtips.com/topic/98158-my-first-build/#findComment-1313144
What resolution are playing at?
The 780ti is, as most said, a better option. You can also put in a lower watt power supply and save some money. In some games, the 780ti actually blows the 770 SLI's out of the water.
In a lot of them, it's right on par.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/98158-my-first-build/#findComment-1313160
Something like an AX 760(i) would be great for both the dual GTX 770's or any single card. That said, for a single card, the older AX 650 would be plenty.
https://linustechtips.com/topic/98158-my-first-build/#findComment-1313174
ive changed to a 780ti and its works out cheeper (did i just say that?) with the CPU for gaming i heard you only get a few FPS more or less with an i7 or an i5. and as to the cost im saving up for it so if it costs more i just have to wait longer (which i dont mind)
https://linustechtips.com/topic/98158-my-first-build/#findComment-1323643
What's the system being used for? What about the peripherals?
https://linustechtips.com/topic/98158-my-first-build/#findComment-1324955
This is not a build log. Please post in the relevant section next time.
It seems like he's asking for advice on the parts he picked so how is this the wrong section?
CPU-Intel Core i7-6700k  Motherboard-Asus Z170I Pro Gaming Mini ITX LGA1151
GPU-MSI GeForce GTX 1060 6GB  Ram-16GB HyperX Fury Black DDR4-2133  Case-Corsair 250D Black
Displays-Samsung SyncMaster 2443BWX (1920x1200) & Samsung 4k TV
PSU-Corsair RMx 850W 80+ Gold   Cooling-Corsair H60 54.0 CFM Liquid Cooler
Keyboard-Corsair K70 RGB w/ MX Brown   Mouse-Razer Naga 2012     Sound-Sennheiser HD 650
https://linustechtips.com/topic/98158-my-first-build/#findComment-1329295
A build log is for pictures detailing the completion and or progress of a build. This should be in new builds and planning. When I posted, the topic was in the incorrect subforum. It has since been mobed .
Feel free to message me if you want to chat!
https://linustechtips.com/topic/98158-my-first-build/#findComment-1331304
oh ok, thanks for clarification!
https://linustechtips.com/topic/98158-my-first-build/#findComment-1334441
I would say get 780 ti, and you can go SLI before a i7 for gaming. After SLI you could either go for i7 or more SSD space/ better peripherals.
CPU: i7-4770k CPU Cooler: NH-D14 RAM: Crucial Ballistix Sport 8gb GPU: EVGA Superclocked 780 ti MOBO: ASUS Maximus VI Gene PSU: Corsair RM 850 Case: Bitfenix Prodigy M
https://linustechtips.com/topic/98158-my-first-build/#findComment-1334611
