Hi! So here's my build:
Pentium G4560
ASRock B150M Pro4
ASUS RX 460 2GB
8GB DDR4
Kingston A40A4 120GB SSD
Be Quiet Pure Power 10 400w / System Power U9 400w
Phanteks P300
My question is, should I get Pure Power 10 / System Power U9? Some people say the System Power U9 will be enough for my build, but it has a sleeve-bearing fan (which is not good if mounted horizontally) while the Pure Power 10 has a rifle-bearing fan. I noticed that the Pure Power 10 is a Tier 2 PSU, while I don't know where will the System Power U9 be placed in the PSU tier list...
Also if you have a better case suggestions other than P300 for under $100, please help me :D
https://linustechtips.com/topic/978210-power-supply-dilemma/
I'd personally get the Pure Power 10.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/978210-power-supply-dilemma/#findComment-11810316
U9 would probably be T3 (low end DC-DC design), the Pure Power is significantly better.
Just some bapo nerd from 'Straya
PCs:
Main: i7 7700K (5GHz 1.4V) | ASUS GTX 1080 TURBO | 4x8GB Corsair Vengeance 3000MHz (3200MHz CL14 1.365V) | ASUS PRIME Z270-AR | Thermaltake SMART 750P | Coolermaster Seidon 240P | Acer Predator X34 (34" 1440p144Hz GSync IPS)
Secondary: i5 3570K | Intel HD4000 (RIP Sapphire HD 6850) | 2x2GB + 1x4GB Kingston 1600MHz | ASUS P8Z68-V LX | Corsair CX650 | Coolermaster Hyper D92 | Sony Bravia VPL-VW80 (108" 1080p60Hz projector)
Laptop: i7 7700HQ | GTX 1060 6GB MXM | 2x16GB SODIMM | OEM Acer Motherboard | 17.3" Screen (1080p60Hz IPS)
iMac: Core 2 Duo T7400 | ATI Radeon X1600 | 2x1GB 667MHz DDR2 | 20" Screen
https://linustechtips.com/topic/978210-power-supply-dilemma/#findComment-11810734
Pure Power 10 because of the higher quality fan, that will last longer than the normal Standard Fan of the U9.
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/978210-power-supply-dilemma/#findComment-11810801
Do you know how long approximately both Pure Power 10 and System Power U9 will last for? (Under air conditioned room, nothing will be OC-ed, 3 intake & 1 exhaust fan, 4-8 hours/day usage)
https://linustechtips.com/topic/978210-power-supply-dilemma/#findComment-11810882
They both come with 3 year warranty periods, so if you have any issues with it during that period you can have the unit repaired/replaced.
Realistically it should outlast the practicality of the g4560 system you're intending to use it in. (In other words you'll want to replace your system before you should have any need to replace the PSU in it)
https://linustechtips.com/topic/978210-power-supply-dilemma/#findComment-11811107
No
There is no way of knowing that.
What we know is that the fan of the Pure Power is certainly better. Besides that, we don't know anything.
It also comes down to external factors like voltage stability (AC), the components used and so on...
https://linustechtips.com/topic/978210-power-supply-dilemma/#findComment-11811183
6 hours ago, Rexper said:
... Bugs.
Oh yeah, of course.
I tend to forget that because its not really an issue in Germany...
But in other regions that is a big issue and forces some manufacturers to integrated anti Bug Foams to the PSU.
https://linustechtips.com/topic/978210-power-supply-dilemma/#findComment-11812208
2 hours ago, jonnyGURU said:
Then why are they called GERMAN cockroaches???  ;););)
Why are they even called cockroaches. No sexual intend ;)
But that's a good question where I haven't found the answer to (who named it, where would be the first to ask)...
https://linustechtips.com/topic/978210-power-supply-dilemma/#findComment-11813511
[insert sleezy racist remark]
Talking about cockroaches, my new shithole new appartment is infested with them - going to bomb the place sometime this week.
https://linustechtips.com/topic/978210-power-supply-dilemma/#findComment-11814516
Dude (I assume), I used to live in Florida. Not to hate on Florida, but we got ants and roaches in our electronics and the sea-salt air would corrode electrical contacts so bad.  Shit would NOT LAST. Everything died in a year or two. Add to that the constant brown outs for being the lightning capital of the world... Might as well not even own a computer.
https://linustechtips.com/topic/978210-power-supply-dilemma/#findComment-11814536
Yeah, I completely agree. I might move my stuff into my car for the time being, because it should be safe there (plus it's off street parking, so should be broken into there). - I'm not close enough to the ocean for the salt in the air to be much of an issue, so that's fine.
The place has both American and German Cockroaches, plus bedbugs. It's not nice. But that's the price you pay for getting a place for under $200 per week in the inner suburbs of Melbourne.
My housemate doesn't understand the problems with getting stuff off the side of the road - all of the furniture - including the beding is from the side of the road - he even got our toaster off the side of the road - FFS, that's why this place has an infestation. But buying a laptop or a phone used - that's a fucking no go, and everything from an Op Shop are just povo items - in his opinion.
https://linustechtips.com/topic/978210-power-supply-dilemma/#findComment-11814843
