4 minutes ago, Sgt.Mak said:
I have a R5 1600 currently paired with a GTX 750ti.. it runs csgo, quake and bf3 well... but pubg and its shitty optimization has the 750ti struggling was looking into a GTX 1080.
Will there be a cpu bottleneck?
1080p?
Quote or Tag people so they know that you've replied.
I would say no, but not 100% sure.
Desktop: Slick
CPU: Ryzen 5 2600    Motherboard: Asus Prime X470-Pro    RAM: 16GB Corsair Vengeance LPX 3200mhz CL16   GPU: GTX 1080 8GB
Storage: Samsung PM981 256GB (970 EVO)    PSU: Corsair TX650M   Case: Lian-Li PCO11 Dynamic - White  Fans: Deepcool RF120mm RGB
Peripherals: HP Omen X 35 Ultrawide (3440x1440, 100hz, G-Sync), Logitech g903, mdr-1000x, umc22 + AKG D5, Drevo Blademaster 87K RGB (Gateron Browns)
Laptop: Surface Laptop 2 Platinum - i5 8250u, 8gb ram, 256gb nvme, 13 inch pixelsense touch display
Phone: Huawei Mate 20 pro 128gb Black + iphone 6s 32gb gold
No, there won't be a bottleneck.
Computer engineering PhD student and RFML researcher
Daily Driver:
CPU: Ryzen 7 4800H | GPU: RTX 2060 | RAM: 32GB DDR4 3200MHz C16 | OS: Debian 13
Gaming PC:
CPU: Ryzen 5 5600X | GPU: EVGA RTX 2080Ti | RAM: 32GB DDR4 3200MHz C16 | OS: Windows 11
For the CPU to keep up with fast GPUs like the 1080; depending on how the game is programmed to utilize system resource, high clock speed does matter than multi-threaded execution. 1600 has got a nice amount of threads but if you don't make them run at higher multipliers than stock, it might be a matter of bottleneck.
console.log("way to pro");
depends on things like resolution and refresh rate. At 144hz your cpu will have more work to do then at 60hz. And because if you play at 4k you will probably not go past 60fps the cpu will have a lot less work to do than say 1080p 200fps for example.
