Industrial water cooler?
Solved by SolarNova,
1 hour ago, BadMonkey said:
This,
Hailea are pritty much your cheapest option, and you should be looking at their HC500 or above. The HC500 would be good enough for a basic system and 'normal' OC's.
But for keeping liquid temps as low as possible (4c without mods) with a highly OC'ed system you would want the HC1000 imo.
if you go SLI, and again really want to go into extreme OCing using a chiller, then consider their top option the HC2200, that iirc has about 3300w of cooling capacity.
Understand the rated cooling capacity is, as far as im aware, for ambient liquid temperature. As you aim for colder liquid temps the effective heat load it can handle drops. This is why you should oversize the chiller for your systems estimated TDP.
