Fans to molex to power supply ?
Solved by dj_ripcord,
You will need an adapter for the fans to be powered directly off the PSU. Perfectly safe. https://www.amazon.com/Phobya-4-Pin-Molex-Connector-Connection/dp/B004CLDSRU/ref=sr_1_2_sspa?ie=UTF8&qid=1538094792&sr=8-2-spons&keywords=molex+to+4+pin+fan&psc=1&smid=A3GO5VFCNOM5I7
However the fans plugged into this will run at 100% all the time. Which can be loud. So use the motherboard headers if possible, they are usually PWM and will automatically control fan speed based on temperature.
