Ryzen 2200G Extremely Hot
Go to solution Solved by jiyeon,
47 minutes ago, TVwazhere said:
Was the CPU cooler installed correctly? (Tightened all the way down?) 96c is just too damn hot
Ah, that's better. I found out only 2/4 screws were tightened from my brother's efforts, so I redid the cooler and applied a generous amount of thermal compound.
Idle is now 24°C and a Cinebench run later yields a max temp of 47°C. :)
Hi, so I just completed my brother's new PC which has a Ryzen 2200G.
I booted up fresh from Windows 10 to find idle temperatures were anywhere between 40-50°C, which is unusually hot in my book. I also did a Cinebench run and at max, it was 96°C!
Where could I have gone wrong? I have a sneaky suspicion that I did not put enough thermal compound, I did let my brother do it after all, with a baby pea size amount.
We're using the stock cooler and 1 case fan on the side of the DeepCool Frame mATX to intake air into the cooler.
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
https://linustechtips.com/topic/976745-ryzen-2200g-extremely-hot/
1 minute ago, Dan Castellaneta said:
40-50C isn't too bad for the stock cooler. What does it run on average in the games he plays?
It's fresh from Windows like 10 minutes ago.
1 minute ago, hconverse02 said:
Pea sized is fine, is the fan on the stock curve and did you change anything in ryzen master?
Everything is absolutely stock and we don't have Ryzen Master installed.
40-50 is idle, 96 is bad but not too bad in cinebench on an apu
Yeah, I know that 40-50 was at idle, which is why I said it's not too bad.
Like @Dan Castellaneta said, what are temps during actual gaming sessions?
We don't know yet because we literally installed Windows 10 like ten minutes ago, there are no games installed yet.
My brother did it, so I can't for sure. You know what, it could just be his bad on this one, I gave him the responsibility of doing the thermal compound and cooler.
Were you there to supervise the process?
You gotta watch your siblings. Those young knuckleheads cant do anything without their older bro/sis 9_9
Yeah, I was the Ed Techsource of the household a few hours ago. :) "Now you're going to screw these ones in, yes those ones."
The CPU cooler was probably barely making any contact with the IHS. 47ºC under load makes a LOT more sense
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
